Retractable Step
Ranger623
I'm a brand-new member to this Forum and own a 2012 Tiffin Allegro Breeze 28BR (shorty). I am the second owner (first time RV owner) and have had for 7 years. Just turned 50K miles. I'm a retired business exec., not a mechanic by any means. But whenever I do need mechanical help for anything major, have to travel long distance since I live remotely on the beautiful Oregon coast. My retractable step just went out. No grinding sound, just a "whirring" sound. Have looked on-line at repair videos and believe I can manage this repair (either replace the motor or the gear box or both), but first I need to know the part numbers of each. Have gotten no response from Tiffin. Would appreciate advice from membership 1) if this repair is above my ability as a novice and 2) where us the best place to shop for these parts and at lowest cost?
Thanks and I look forward to hearing from other members on this inquiry and all other I'll probably have in the future.
Let's hope it is just the motor. Is it a Lippert ? If it is, the job is not too difficult. This is a link that should provide you with some help Kwikee Electric Steps Replace 366043 RV Gear Box Linkage with Motor
I'm not sure if Amazon will sell one but you can buy just a replacement motor from NAPA without the gearbox. It is a Ford power window lift motor for a left front door. Off hand, I can't remember the year or model right now. If it is not the motor or gear box and the teeth on the bracket have worn, I have had a Machine Shop rebuild mine for a lot cheaper that purchasing from Lippert.
Good luck
Darrell
@Ranger623 can you provide a picture of your steps? Also if you can a picture of the underside which is where the controller and motor reside. Not hard to replace, these steps aren't the best technology.
Good luck
Darrell
Thanks very much for the response. Is 366043 the gear box compatible with motor 163669? Got the motor ID from Tiffin but cannot find the gear box number they gave me, nor can I find a cross reference chart matching the motor ID to the gear box ID. My local mechanic quoted over $1k to repair (apparently he wants to retire early).
Are you sure you need the Gear Box? The best thing for us is to see what your configuration is. As Neil suggested, a few photos of your step top side and most important the underside. I think it is rare that the gear box would fail. More often it is the ":gear" on the drive motor that fails. The motor costs just over $200.00 from e trailer and just over $100.00 from NAPA and is held on with three screws. For me, a 10 minute job to change. Here is a youtube link
Darrell
Darrell
Darrell
You're right. I'll replace the motor. Greatly appreciate your advice.
Will let you know the outcome.
Thanks again
Welcome to RVforums from Ely, Iowa. From the for what it is worth department. I have the same or very close to the same motor in our coach. Two things; to check first there are two door switches one at the screen door and one underneath the coach, The screen switch actuates the steps and the second switch indicates when the steps are retracted. I have had my door switch go bad easy fix. The second item is the motor you can remove this and actually take it apart and clean and lubricate the gears and clean up the motor. I have also done this and the motor works like new. I did this about 5 years ago and still working. It seems to me there is a you tube out there on this. For the record my rig is a 2007 so technology may have changed.
