Rhino Elbow Failure
MapNerd
RVF 1K Club
Prince William, VA
Ventana 4326
2020 Ford F-150
Staying at a state park where the sewer connection is uphill from the pad and on the wrong side. Annoying but no problem, I don’t have a Sanicon (Newmar wouldn’t add it as a special) but I did purchase a Remco Bayonet-Style Macerator Pump and garden hose to lugged bayonet fitting for just this reason.
Hooked it all up yesterday
RV Sewer Drain —> 3” Rhino Elbow Fitting —> Remco Macerator Pump —> Rhino Rinse Hose —> Garden Hose to 3” Lugged Bayonet Adapter —> Rhino Sewer Elbow —> Sewer
Opened black, turned on the pump and it worked great. Closed black, opened grey, no issues. Pumped it all to sewer via a standard rhino rinse hose
Went to do the same today, opened grey, turned on pump. Realized I might as well drain black so stopped pump, closed Grey, opened black and turned on pump...BOOM!
all I saw was a wall of brown coming straight at me as I was crouched under the FWS. Immediately reached in to try and close black but turns out it’s hard to find the handle when you’re taking raw sewage to the face.
moved back and started grasping for the water hose - black tank still flooding the campsite. Wife came out, reached in and shut off black which at this point was now empty. She grabbed the water hose and hoses me down. I walked over to the bathhouse thankfully right next to our site, still completely unaware of what happened or why. Immediately took everything off and started rinsing and scrubbing. DW brought fresh clothes, soap, peroxide and a towel to me.
After taking one of the most vigorous showers of my life, I walked back over and immediately I see what has happened. Something that never occurred to me as even being possible.
The elbow failed causing the Macerator to fall to the ground and all of the tank contents to rush forward to whatever waited in front of the drain, which was me.
after spreading kitty litter over everything, sweeping it up and binning it, then thoroughly rinsing the pad and vegetation, and rinsing, cleaning and disinfecting the wet bay I took this lovely photo, one end of the rhino elbow fitting still on the drain, the other end still on the Macerator pump.
We found the clear elbow a few minutes later, 15 feet away. If it’d hit me in the head I might have had the misfortune of getting knocked out and literally drowning in my own feces. Thankfully, I just have the misfortune of having to live with the experience of having been drenched in my own stink.
It never occurred to me that an elbow could fail like that but in hindsight it’s kind of obvious. Those elbows take on an awful lot of pressure and nothing holds them to the connection except the bayonet lugs, which is fine except what holds the elbow to the bayonet fitting? In making them easier to work with by allowing these fittings to rotate and spin freely against their connection, manufacturers have to basically create a friction based attachment between the bayonet portion of the fitting and the plastic elbow which is where all of the lateral force is applied before being forced downward and into the drainage hose. As a result, you lose a substantial amount of strength on these fittings that are taking a lot of pressure from 45+ gallons of wastewater rushing towards a central point. Given that the desired connection is almost always straight down from the sewer drain and through the hose port, I will be looking to create a permanent elbow fitting here.
Now please excuse me while I go drink an entire bottle of everclear...mixed with bleach
What a HORRIBLE experience!:sick:
I have had worse days but it’s hard to remember when
Yikes. Thanks for the warning.
I had a Rhino 45 degree elbow come apart but fortunately it was after I had dumped and was flushing the tank...not pleasant but less of mess then MapNerd experienced.
Safe travels.
Maybe the lesson here is still with Valterra? And why the heck did Newmar switch black and gray tank sides? Black is LEFT on mine.
I read you post in absolute horror and then got to your last line, "Now please excuse me while I go drink an entire bottle of everclear...mixed with bleach." and almost fell out of my seat laughing. Lawd, what a nightmare. That is definitely a traumatic experience. If I were close by, I'd be pumping you and your wife with tequila.
Well, I've had my "dark days" at the wet bay, been there done that. I seem to remember a story of someone (cough) wrestling their anaconda sanicon hose with a cap still on it once upon a time? So yeah, a few of us have enjoyed such an experience.
Lesson for me is that I am done with adjustable elbow fittings. Solid, monopiece fittings only.
I’ll take that tequila now @ARD
We just watched the DVD "RV" from 2006 with Robin Williams. In the movie he had a stroke of bad luck dumping the crapper too. I guess if there is anything positive it is that you didn't have your mouth open when it happened!
Note to self: Don't stand in front of tank drains when opening them.
The upside since you drained it the day before it could have been worse.
Seen it. Certainly thought I was in it. Then reality sank in.
That’s the worst part about it all. I’d wired my Macerator to a 12v RV remote so that I could stand by the sewer and make sure the hose didn’t pop out. There was no reason I had to be sitting in front of the drain. I just turned it on and figured I’d walk over to the sewer inlet while it ran.
Unfortunately, I did not make it.
And I just bought Rhino drain hoses.....
I think the hoses are fine, I have rhino hoses and plan to continue using them but I just ordered a solid, one piece elbow from Amazon and I will never again deviate from that critical component.
I'd be questioning how I stepped on karma's toes. lol I do that occasionally with mishaps then I pledge to be a better me. ☺️
Is this what you switched to:
Sorry it happened to you MapNerd.
Has anyone here ever thought to use Waste Master? I have had it on my last unit and now on our new 5'er. Cleanest system to use and easiest also. Tough as you can ask for and the connection is what they should all be. Only the RV industry choses to use such a bad connection system.
Pretty neat system but since I had to go uphill, it wouldn’t have solved my problem. That said, I do like it. I’d seen it a few times and wondered about it. Hate the green color but everything else about it seems pretty top notch.
