- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
3427What was $7? I am not seeing it.
The RVIA sticker also had to go but I recorded the sticker # in case anyone ever cares. This was a one year model like the VT and DS 3724 in 2017. Not very popular I guess, but it suits me perfectly.3427
Huh....learned something new. Had to go look at mine again.I would just remove the lettering altogether, luxury line doesn't use them.
I noticed that after I upgraded my model # …I would just remove the lettering altogether, luxury line doesn't use them.
I've threatened to do this with some sort of red line but dots would be great! Where do I get the red dots?Another cheap easy one for those of us with analog gauges, putting dots where the gauges would normally be when all is good while driving. just a glance tells you all is good, or not. View attachment 163
Never mind, J&JD. I read a little further and found the link.I've threatened to do this with some sort of red line but dots would be great! Where do I get the red dots?
Where did you have brass water quick disconnects?I had the brass water quick disconnects replace with plastic Banjo-type fittings and like them a lot better and there is no restriction of water flow.
Then I use these to keep the critters out.
On my black tank flush hose, my water connection to the coach, both ends of my external water filter, and on the Y connection on the pressure regulator that hooks to the campground water supply.Where did you have brass water quick disconnects?
