Rigging awning windows
jsorensen
Hi Intech owners - potential future owner(s) here with a hangup. We love the Willow but really dislike that all the operable windows are those emergency hatches that barely open. I know there are some 2026s out there with sliding windows, but all the available ones on our half of the country (west) are the emergency windows. It seems like there were very few 2026s with sliders, and all the new 2027s have the emergency windows now, which just seems like a strange design choice.
Anyway, has anyone rigged their emergency windows with telescoping arms or something similar (found in other brands like Little Guy) to be able to prop the awning windows open wider and hold them open? Or found anyone online with an Intech doing so?
Thanks!
I would find windows that push out at the bottom perfect. Many sliding windows fill with dirt in the track and need constant cleaning to slide freely. The drain slots plug over time causing leaks. Need to be closed when you need ventilation most to keep rain out.
More to your question. As long as the hinge stays together you should be able to lengthen the system to add more lift. Mods are allowed.
Right, the awnings aren't the problem, we have overland windows our our current camper and prefer them over sliders, actually. It's the fact that they made all the awnings emergency windows that only open 4 inches. Thanks!
I am happy to be able to compare the sliders of our long-owned 1989 HR previous-use motorhome to my frameless Intec 2026 OVR Navigate's windows, same design as yours.
The slider window felts, as I called the fibrous inserts under the sliding glass panes in our 1988 motorhome, got wet by design, from rain. The slotted drains sent the excess bulk water there on to the outside, but the frequent, recurring rains at our Florida home kept the felts in a lily pad slimy mold growing state all summer when home.
Fast forward to our 2019 Intech Flyer Explore: It has a slider. It built up a hidden dirt dam outside under the rubber trim and the rainwater that could not reach the drain slot spilled over to the inside. AARRGHH!
Now we have the frameless windows in the OVR. Yes, the red latches are wonky and the screen frame fitment seems odd, those being snapped inside, but a shut OVR window wont be growing slime mold or spilling water inside. We camp in Southeast summer temps a lot, windows shut. In cool weather, the multiple speed Maxx vent fans will bring plenty of air through the barely opened windows.
Keep in mind that if you free the red latch and push the glass out too far, it will release from the top hinge and fall to the ground. I ain't modifying ours!
Enjoy that Intech. With the OVR bought so Mrs T has a glamper, we still kept the 14 foot Flyer Explore for my trips that Mrs T does not go along on, my work being done for others only needing a nights place for one to sleep.
If you really need a slider, measure the opening where you wish to have it, buy one that size from the Lippert catalog and install it. Maybe one or two swapped into the right spots would be enough?
Thanks for your thoughts and advice on this. I got the window measurements from Intech and have been pricing out tern overland replacements. My hope is to still just be able to attach some cam-lock struts to them, since that would be easier, but will need to spend some time with it first. I'm sure the hinges could be swapped out too. There's always an option depending on how far you want to go!
Glad that you are working toward getting it to be right for you. I offered caution on possibly freeing the widow from the upper hinge and having it fall off, but I have not done a swing out test on ours to know how far is too much. Could be that an extreme angle would be required to disengage the hinge, an angle that your strut mod would never get near to reaching.
Also - The Willow along with the OVR and several other models got a Intech Service Bulletin in July to add a Entry Step Filler Piece to close a gap at the top of the entry stairs between the top threshold and the top tread.
Intech responded expediently with this bulletin, coordinated by my excellent Jacksonville selling dealer after I let my dealer know that I had stepped thru the gap and got scuffed skin from not watching where I put my right foot while turning back to gab a tool bag.
All Willow inventoy you might see already on dealer lots will be getting the filler piece installed, and new production units will now already have the filler in place leaving the factory.
If you see a big gap at the top of an Intech entry stair, ask if the dealer or owner has received SB # 072326 and the free part that Intech includes for fastening the fix in place. Intech didn't hesitate to mitigate that small detail, just on my notice to the dealer alone.
I hope to get a factory tour someday. The videos of the build are interesting, and I was given full dimensioned and parts listed Solid Works drawings in pdf form of all of the aluminum frames, every where, for both the Flyer and the OVR, after a simple email request. No guessing on where to drill/not drill during mods and additions.
Hoping you get that Willow and can adapt it to suit you just right!
Thanks!
2026 Willow and we haven’t found the frameless windows to be an issue, it was one of the upgrades we looked forward to. There is so much glass area that the air flow is great when the windows are open five or six inches from the bottom that the red handle allows.
The Maxfans pull air through the coach if the outside is calm.
Our previous Grand Design Imagine had sliders, we have found the airflow in the Willow to be much better than in the Imagine and it was very good. Further, the windows are easier to open and don’t require dry lube to get them to slide.
What’s the issue that is a concern?
