Roadtrek RS Adventurous Electrical Diagram
mtatkow
Have been working on cross checking and updating a wiring diagram for my 2018 built on a 2017 Sprinter (which should be the same as similar years). Mine has the outback package with no propane, UHG, diesel Alde, dual solar systems (total in the 470w), Voltstart and two 3000w inverters, one for coach, one for galley. So far I have done a reasonable amount of cross checking but am not complete. The attached diagram is based both on what I know and a diagram dated 2019 from KS2 that I have in hand, but is not yet fully verified. Per a recent back and forth with Roadtrek (who qualifies their responses by stating the obvious - they are not the same "Roadtrek" that built my van in 2018). The van is put away for the season and I will not get back to this until spring.
Looking to see if there is any interest in me posting my results to the forum as I go along. When complete with my verifications I intend to add some more battery to the AGM side while maintaining the existing pair of 200AH ecotrek modules, with eventual goal to replace the modules with more standard hardware.
OOPS - I posted the KS2 diagram instead of where I stand. One item to note - I replaced the antiquated blue ray system with a 5.1 amp with its own bluetooth and the TV with a more modern Fire TV. You will see a small 150a inverter for the new amp (which is actually 300w - a typo) so I can run the sound system without having to turn on the inverter. Reduces some of the system losses while not plugged into dock power.
