Rooftop A/C question
PilotKev62
Oakland Tn.
Fleetwood
Southwind
Chevrolet
Workhorse V8
2004 fleetwood southwind. , Coleman A/C units. One was not functioning but when turned on it makes humming noise. After watching videos I determined it could be one of the capacitors. I went on top pulled the cover off and with the switch on I spun the fan shaft with my hand and it started running fine and producing cold air.
Then I shut it off and now it’s starting again on its own. I’m thinking it sat a while without using it and maybe it just needed that to put more electricity in the capacitor and now it’s storing it properly? Or maybe the capacitor is starting to fail and maybe I should just replace it anyway. Also there are three of them and I’m not sure which is the start capacitor and maybe just replacing all three is the way to go being they are cheap?
Replace the caps. The small one should be the fan...maybe 5uF. The other is for the compressor. A third could be what's labeled as a 'hard start' cap. Just remove it. Also...it wouldn't be unusual for the fan motor to going bad. On my '08 I have had to replace it on both of my units. Good luck. (P.S. if you do decide to replace the fan motor they will come with a new cap just fyi)
Thank you so much
Also, if you put a couple of drops of oil on the fan motor shaft, right next to the housing. The motor may last a long time.
My 95 fan motors are OEM, They get a little oil every few years.
Richard
Thank you for the reply, I will do that as well.
