- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I've been using adjustable water pressure regulators since I started RVing in 2017. I've been through probably a half dozen as they seem to not be "adjustable" and are poor quality. For example today I know the spigot is high pressure but the regulator is showing 20 psi. I have a water pressure tester to put on the spigot but didn't use it, that would require walking all the way around to the pegboard bay
I went to Amazon to put a new Valterra adjustable regulator in my cart and stumbled upon the fixed flow rate version. I've known of these but thought they were fixed at around 40 psi. Now I see there are multiple versions such as one for 50-55 psi and ones for lower psi ratings. As my KOA is right next to a camping world I figured I'd stop in there and take a look at what they had. They had the two items in my Amazon cart so I figured I'd pick up the fixed flow rate one that's 50-55 psi as that's the pressure I like to run.
Also of note is I put my water pressure regulator behind the water reel. I believe there is pressure lost from the spigot to the RV so setting something like 50 psi at the spigot is not going to be 50 psi inside the coach.
So far I am pleased with the fixed rate water pressure regulator. The results within the coach are as expected.
Valterra adjustable regulator:
Valterra fixed flow 50-55 psi:
Valterra fixed flow 40-50 psi:
