Question Sewer door opens when driving -
Hot Rod John
new road trek chase - sewer door pops open and drags on pavement until another driver waves at you - factory magnet on door is not effective - any ideas please-Hot Rod John
If your under warranty, have it looked at before looking at a fix.
Good morning, Hot Rod John:
If the same as my Zion, I had this problem too. I think you are referring to the larger outer panel in front of the driver's side rear tire that swings down to access the black/gray water release valves (not the smaller locking panel that houses the hose connected to the macerating pump). This (larger) panel has two magnets affixed to the panel's interior top-edge that connect to two magnets mounted on the end of the brackets. The brackets are affixed to the vehicle frame. I resolved the issue by *gently* adjusting the brackets so that the two magnet tips had a stronger connection to the door's interior magnets when the door is closed.
After adjustment, test by shaking the panel by hand to ensure a strong magnetic close. The panel should not open my merely shaking it. If it still swings open, further adjust the brackets (gently).
Hope this helps.
Hope this helps.
Thanks for the advice-My unit is the Chase model and there is only 1 set of magnets on rear side of panel. No space for more magnets-will ask Roadtrek HO in canada if there is an alternative solution besides a strap. Thanks for the advice. Hot Rod John
Color matching Velcro strap on the outside if there is no room for additional magnets.
