Shattered roof window
If it's a skylight, ordinarily you'd replace it.
Safelite?
Welcome to RV forums from Ely, Iowa. My assumption would be RV shop or auto/Truck body shop
It's a simple operation, first however, the correct size skylight has to be located. You can measure the opening from the inside, no need to get on the roof and that would save a mobile tech a trip out. Order the part and hire a mobile RV tech to remove the damaged skylight and install the new.
