- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Of course not, it's me doing it!!! It's time for an eauuurrrlll change so simple enough, done'did'it before. The hardest part is that dang panel blocked by the exhaust, thank you Newmar. After finding the right screw to remove those two screws to drop the panel off I go. Easy peezy. Of course not. Old filter off, new filter on, after eaurrrrrll was drained of course. Oil in and test run. Shut down to check eaurllll and it's near empty, blinking light, Neal fail light illuminated! Long story short is when you remove the old filter make sure the o-ring comes with it. It obviously stayed on and when putting the new filter on that has an o-ring on it you get double o-ring'd and hence a disaster that I'll address another day. Hopefully I can re-use the same filter but I have another coming tomorrow.
