Slide covers
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Yes
After 3+ years full time I finally had slide covers installed. Are they adjustable? Anytime it rains, or whatever wet, the water settles on the covers. Plus wind or whatever water will settle under the topper and on top of the slide. Then when we are moving when we bring in the slides the water (A LOT) runs down the side and some runs off the slide top and on the floor inside.
I’m thinking if the topper was tighter there might be less water thus less run-off.
It should be taught when rolled out. There's an adjustment on the edge (not sure which one) that you should be able to take up the slack. It shouldn't hold water. Blessings
