Don’t come here and start arguments. You asked for advice and got solid advice that you immediately argued with.They are not
Thanks for putting it more eloquently than I could have.Don’t come here and start arguments. You asked for advice and got solid advice that you immediately argued with.
Fact is all trailers have the same potential for perfect toe as they do for disastrous tow.
How you load the trailer and balance the weight is 80% of the determining factor. That’s on you, not the trailer.
The tow vehicle plays into the equation, as a proper tow vehicle can make up for a poor loading weight distribution to a certain point.
You can never have too much of a tow vehicle capability and you can easily have too much trailer for a tow vehicle.
All trailers are going to be very similar. There will be two key considerations.
1. Making sure you have enough truck to tow it. Not just in terms of towing capacity but also payload, which is going to be your limiting factor.
2. Making sure the trailer is loaded properly with the tongue weight at 10-15% of the total trailer weight.
A good weight distributing hitch with sway control will also help. Get a reputable hitch shop to set it up properly for you when your truck and trailer are loaded up as if for a camping trip. Don't trust an RV dealer to set it up for you.
Good point. When we were shopping, we only looked at one particular shape of trailer so I kind of glossed over that in my mind.You left out one critical design criteria that results in a stable tow: aerodynamics. A high profile, slab sided trailer is inherently more unstable than an aerodynamic, low profile trailer. A slab sided trailer presents a lifting force to the relative wind. The dramatic videos of lightly loaded semi trucks in a strong winds makes the case.
