redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
That’s a good method. I currently am using a library I found that utilizes BLe data and puts it in MQTT.@redbaron I forget the thread we we had discussed the integration of the BMV-712 data into HA, but ....
after a few years, I finally to around to this, I put together a Wemos D1 mini V3 with a DC power shield and connected it via a JST-PH connector to the VE.Direct port on the BMV-712 per the Schematics section of the instructions. I installed esphome on the D1 mini per the esp8266-example.yaml example (creating secrets.yaml as appropriate). I connected the DC power shield to 12V (power and ground wires).
Power it up and I got the house battery data loaded into MQTT. Now to update HA to display that data. Didn’t take very long to setup. I still need to clean up the install now that I know it works.
I have converted my existing AGM auto gen start to use SOC by disabling AGs for battery in the Silverleaf and allowing HA to control.
What I have noticed is that BLe data is accurate within 5 minutes but does get about 30% drop rate. I don’t think this matters, but your solution would be far more accurate.
