solar panel
labill
Hot Spring County, Malvern, Arkansas
Bay Star 2901
29'
Ford F53
V-10
I have a small solar panel on the drivers side roof of my 2012 Bay Star. I was told its for the battery. Is that right and how can I check to see if it's working
You should be able to put an ohm meter on it and see if any voltage is coming down from it.
And yes, it is for the chassis battery.
There should be an inline fuse on the wire from the panel...not sure where as I have a DP and not a gas unit...but it should be near the battery... ? You can use pull the fuse and use that to measure the voltage.
