FYI Starlink Mini on sale - 299
Yep, my plane has a skylight (like sunroof) which is why my Amazon list shows the suction mount contraption.
I got the tripod today, it's really nice and looks like it will work with any of the Starlinks. If you're looking for a tripod, this one is worth a look.
You could probably use the suction cup mount and attach it to your windshield.
Does the router on these have the same output as a standard Starlink router? I have heard of people putting one on the dash as they go down the road.
The router is built into the Dish. You can route the dish on the roof and the router wifi would let you connect to your device. You could put the dish on your dash and maybe get a satellite signal, I have not tried that. I have mine on a telescopic pole that I put up and take down each time. I have not used it in motion over more than a few blocks that way.
My question is more about the range of the wifi signal of the mini. IOW, if it is on my dash, will I be able to stream on all TVs including the bedroom and exterior ent center?
Starlink mini router, from a quick google search, has a 150ft range. Your coach is only 43ft, any wi-fi router should suffice for that length.
There are alternative options depending on your coach Wi-Fi setup. For example, I use a pepwave to broadcast Wi-Fi to my phone and all devices in the coach. You could consider the Starlink Wi-Fi like Campground Wi-Fi so you bring in the external source (WAN) to your pepwave, if you have one, and then that goes out of the pepwave like before. I actually use an Ethernet connection on mine so my Starlink connects to my Pepwave over Ethernet and I don't even use Starlink's wi-fi.
Short answer YES
Long answer posted, you have options to keep things even simpler if needed and change Internet sources without ever having to change Wi-Fi connections on streaming devices, TV's, computers, Alexa's, etc.
Perfect. Thanks @Neal.
Short answer YES
Neal,
Great explanation! I’m doing exactly as you describe using Starlink WiFi as a WAN as my source via a Peplink BR Mini 5g. The Starlink Mini has provided a great signal for our 35’ Bay Star and it located on a Flagpole Buddy mount. It’s worked so well I ditched Dish network and just use Apple TVs everywhere now. So I have same YouTube TV in the coach as at home.
Bill
Short answer YES
@Neal Are you using the Gen 3? When you say Starlink connects to your pepwave via ethernet is that the dishy direct to the pepwave or Starlink Router to Pepwave?
The last used Starlink for me was the Gen2 with the motor in it. I purchased the Gen 3 "Standard" which I have yet to use but my coach is wired for it via a PoE power supply so when I connect the ethernet from the dish into it, there is an ethernet that goes to my Pepwave BR1 Pro 5G WAN port. This is how I bring in outside Internet (aka WAN) via SL into my Pepwave. The alternative option is connect the Pepwave to the Starlink Wi-Fi just as if it was Campground Wi-Fi, and then your Pepwave broadcasts its Wi-Fi to your devices within your coach so you never have to change Wi-Fi connections.
I now added (not yet received) the Mini which I can use in the car, plane, or RV. Long ago I bought the flagpole buddy adapter for both the mini and standard (gen3) so either of those will work to go on the pole on the ladder mount on the back of my coach. I will have both dishes on hand anytime I travel, the mini will likely stay in the car for emergency use.
@Neal Thanks for the info. You confirmed my thought regarding a PoE is needed for the antenna if the Starlink router is not used.
Here's my post on it:
I have only used it inside and around my motorhome so can't help you there. My understanding is you can hook it to your own router and use it for ethernet or wifi.
Does anyone use this app for satellite location? Is it necessary?
My Starlink Mini arrived yesterday and my Amazon pallet of Mini gear is in the garage :rolleyes:
Forced activation will occur 30 days after shipping and I hope to be in the coach at that time and use it. I did a quick google and you can't power it with PoE due to power demands so that's fine, I have the various cables to use other sources as needed.
What's even better is that this Starlink Mini is such a thing that now every 3rd post on Facebook and Instagram is now a Starlink Mini accessory ad! :( Mainly power or mount solutions. Some neat innovation to see at least.
