JeffAndPam
- Jun 26, 2023
- Alabama
- Fleetwood
- Flair, 34R
- 34'
Our car battery kept getting drained, and it took a while to find out why.
First, on the Panel pictured below, in the top right corner I have the ability to switch to "AUX BATTERY", which is the car battery.
When I put a volt meter on the negative terminal, I notice 10v being pulled.
When I go to switch this OFF, I can actually hear the audible switch occurring. (BTW, the LED below the switch never comes on). I also notice the voltage pull on the car battery drops to almost 0.
THE ISSUE: I found that whenever I start the RV, it apparently automatically switches on the AUX BATTERY switch. (Since the LED wasn't working, I was unaware of it until recently). After starting and shutting off the engine, when I go hit that switch to OFF, I hear that switch occur. If I ever forget to do that, I get a dead battery, even when connected to shore power.
Reading through the manual, I see the following mentioned:
That seems to confirm what I'm experiencing. But it's draining my car battery every time I forgot to switch it to off. I can't see that being an original manufactured "feature." Am I missing something?
The main and auxiliary battery disconnects are automatically
engaged anytime the ignition switch is
turned on.
