Problem Suspension Problem
Recluse
Boise, ID
Nexus
Wraith 34W
International
Cummings
2005 Honda Accord
Right from the start, my Wraith rode like a hay wagon. I discovered that - even though my weight is well below the GAWRs, the rear springs were sitting on the bump stops. There were NO REAR SHOCK ABSORBERS installed at all! A suspension expert told me the front springs are two long thick leafs with little arch in them. After replacing the front leafs with three lighter leafs with more arch, adding 2 leafs each side in the rear, and installing mounts and rear shocks at a cost of $3000 it now rides like a truck should.
My Ghost rides on rear air bags. It’s built on an International MV Chasis, what is the Wraith built on
MV chassis with leaf springs
I just bought A 2020 wraith, does this unit charge the house Batties when you drive? Or is it two separate units?
We have the same problem; can you tell me who did the work and how to contact them?
Lonnie, my Rebel 32R charges the house batteries from the alternator. There is a battery isolator behind a panel in my battery compartment which I replace with a Li-Bim when I changed my house batteries (AGM) to lithium
