Tank filling up too quick
TinaB1972
Need help please !! New owner of an old 1990’s rv. I had the tank cleaned out maybe 2 weeks ago and the tank in the bathroom toilet is starting to pile up again. I have used the recommended chemical to breakdown waste and followed the directions and don’t understand what is going on, why it’s happening or what to do about it.
I have really tried to leave this alone! In my child like mind this could go in almost limitless directions.
However I know this is serious and not a joke, so!
When I was using a holding tank, or should I say we, the unpleasant duty of dumping the holding tank was on average every 14 days.
To much or to little water was typically a problem, but to be honest we were probably just full of it.
I would notice that the consistency was from a clay to clump depended on our intake. Clay piles at the input when staying in one place. A turbo wand cleans great when dumping the tank! My tank was poly, so I could inspect the tank and tell when it was clean by the tank floor (my home was a winnebago, yours could be different). If my wife's eyes were brown, I could easily have blamed any problems in this area on her! But alas we both had blue eyes.
May I suggest a clear fitting on the gate valve to determine how thick the discharge!!! Then you can figure what the solids ratio is!
Sorry! I could not help injecting a little humor in my answer.
As a new RV owner, are you also new to RVing?
Don’t want to assume anything. Do you leave the valve open to drain the black tank all the time? Or do you keep it closed and only open it to dump when it is getting full?
Black tanks need the liquid in them to keep things from solidifying.
Most recommend keeping the black and gray valves closed until bumping. Letting the tank build up helps it flow when the valve is open. Always be sure the black tank gets enough water. Sometimes adding water down the toilet when dumping can help. Some units have a city water hook up that can help flush the tank as well. Dump the gray tank after the black. It helps rinse out the hose. When going down the road, we generally put some water in the black tank (left over ice is good) and a small squirt of dish soap. The soap might not really do anything but it seems like it makes sense.
Ken
I have no water anywhere in this rv !!
So you now know you need water to use the toilet! Is that an option?
We have been using water when going to the bathroom ~ before using it I bought the chemical stuff that breaks down waste an added the amount of water it said ~ it’s only been 3 weeks and 2 people using it since it was emptied by a company. Definitely don’t have the “tower of poop” happening !! I don’t currently have access to filling any tanks with water
I would like to suggest a couple things!
Download and read the PDF file humanure handbook. This is a common approach for people who need to get systems worked out. I may be reading to much in this, so don't take offense! The truth is the approach is more convenient for me, so I use it personally.
Consider watching Bob wells videos on YouTube! "Cheep RV living for ideas while working things out!
On re reading this I see you said "New owner of an old 1990’s rv". What make and model, type of RV? You appear to be trying to live in it without hook ups is that right? Is there a sewer line on the property? No water hook up earthier? Just so you know the chemicals for the black tank break solids down but don't make them go away.
Bill
