Technical Installation Question
Darsawin
I feel I'm being gaslit by Camping World.
Can anyone tell me if this gap (see picture) is acceptable? If you zoom into the picture, you can see the window frame, the internal foam seal, and then a gap between that seal and the motorhome's wall.
This a Lippert cockpit window installed on a 2022 Thor Freedom Traveler Motorhome.
Lippert's technical assessment came back with the attached picture marked and said this: "The photo that you have provided below is a clear indication that your window was not installed properly and can be denied for a warranty claim if one were to be submitted. Every section of the window frame should make contact with the sidewall."
Camping World Tampa (Dover, FL) said this: "Good afternoon,
I have spoken with Thors Technical team, and they reviewed the photographs of the windows along with the original engineering drawings. During their review, they verified that the windows are installed as designed and confirmed that there are no missing components, spacers, or shims that would affect the fitment.
For your reference, I have attached the window blueprints provided by Thor. Based on their review, the gaps visible around the windows are consistent with the intended design of the coach and do not indicate an installation defect.
I understand your concerns, especially given the previous issues you experienced with the windows. However, based on Thor's assessment and review of the design specifications, they have confirmed that the windows are installed as intended by the manufacturer.
Please review the attached documentation and let me know if you have any additional questions."
Looks like a standard Lippert framed window. It has two sealing interfaces - the primary interface is where the inside of that frame face is pulled against the outer wall, and that interface is sealed with butyl tape or foam tape, both of which only work in compression. The other interface is along the edge where sometimes a second level of sealant is applied, usually a non-self-leveling cap-type sealant to keep water away from the edge of the primary seal. Neither of those sealants is possible in the picture you have shared.
