The Famous Elbow
Guido
Heard a pop didn’t know what it was at the time. A few minutes later check engine light and loss of some boost up a hill. Drove an Hour to rv park and next morning work on figuring it out. Easy repair and found silicone elbow by share luck. Truck shop had 2 which I bought. Easy repair with battery ratchet.
Same thing happened to me earlier. How did you figure out the problem? I was clueless and had to take it to a shop.
Did it burn through or rub until failure? Cannot tell from photo
Side topic - battery ratchet has become a standard in tool bay for the last few months 😊
Mine just blew out. It’s located on the pipe that feeds the air compressor. This was when I learned the air compressor gets its air from the turbo.
I heard some air in that area and started feeling around with my hand and found it . It looks like it rubbed on something. while driving the wife and I heard a pop and looked it each other like what was that.
That's a pretty loud pop to hear that all the way up front while the motor was running.
That is a common issue with the ISL. It's a Chinese made hose and splits up the back. Freightliner thought that was my issue when I loss power and threw a boatload of codes. They immediately checked that hose and it was good. Mine was a turbo o-ring that may have been damaged when my fan clutch was replaced. I should have bought that hose at Freightliner and carry it as a spare. I'll need to find a part number.
