The Whole Kitandkabootle (is that how its spelled?!)
kenclench
Ventura CA
Rexhall
Vision
Chevrolet
Back again! This is the converter cabinet, obviously. 97 Rexhall Vision. My question is, is everything I see in the lower cabinet the converter. Or, does any of that stuff stay? The fan isn’t working, and I’m pretty sure the converter is worn out. I’m just gonna replace the whole thing. Thank you 😊
View attachment 19067Back again! This is the converter cabinet, obviously. 97 Rexhall Vision. My question is, is everything I see in the lower cabinet the converter. Or, does any of that stuff stay? The fan isn’t working, and I’m pretty sure the converter is worn out. I’m just gonna replace the whole thing. Thank you 😊
Oh! And, how do I check with volt meter? I’ve researched that, and I can’t figure out where to touch the leads. Do I check Ohms or volts?
My guess (more than a guess) is the colored screws hold the front on the panel.
You will be much happier with a 3stage charger converter, what you have is not!
Yes the whole bottom mess is the converter, but as you can see, when you take it out the cover has no where to anchor without some metal work.
The red wire should read 13??on the meter (voltage dc 24) on the meter. Ohm would be used to verify diodes don't leak, and a circuit is not broken or shorted. More uses but that is what you will use it for.
I would see if there is room behind where you can put the new converter, and extend the wires to reach it.
Oh one more thing! On the right side of the converter are the diodes. They are pressed into the aluminum plate,,and connect directly to the transformer.
Send your picture to Randy at BestConverter - Converters, Inverters, Electrical Supplies, Electronics and he‘ll be able to identify your existing converter and suggest a modern converter that will fit in that space, likely one of the “upgrade” converters. Then it will just be a matter of removing your existing converter, identifying the various leads, and installing the new unit. It is not a complicated or difficult job, but you need some direction to get it right.
The pic below (from this:PD4655V 55 Amp Converter Upgrade, Optional Remote Pendant-PD) is just an example but shows that the old unit is easily removable and direct replacements are available.
I've done it in the past (a 1993 Tioga if I'm not mistaken) and the swap out is relatively easy...the contortion ? Not so much 🤔 Blessings
I’m just confused on where all the wires go.
In the photo the red, black, and blue come down from the breaker panel. I’m the left, there’s the whit, and black wires.
The replacement converter doesn’t seem to have all of that.
Crap. Please pardon all the typos…
Do all your wiring with the coach unplugged and generator off, and the house batteries disconnected.
The wires on the left come from the breaker panel and provide 120v ac to the converter. Black is hot (connected to one of the breakers and should be labeled “converter”), white is neutral (connected to the neutral bus bar with all the other neutrals), and hopefully there is a bare copper ground somewhere although I don’t see it.
The wires on the right provide 12v dc. Red is 12v + to charge the battery, white to the neg side of the fuse panel, and blue to the 12v + camper loads on the fuse panel. A proper replacement converter will have all these connections.
Consult to manual for the new converter to confirm connections. They should be clearly labeled. The picture in post #4 is just an example of a direct replacement chassis. Do you already have a new converter? If so what make and model?
So using ohms on the fuse panel check red terminal to top side of open fuse holder. Should have continuity. This will be positive terminal if it has continuity. White terminal should be negative. My guess is blue goes to battery positive, that is a guess! If that is true then blue and red can be tied together, and connected to converter positive terminal.
Other than that all you need to do is feed the power cord with 115vac.
kit and caboodle 🤓
Although in this case, the “Kit“ will include the new converter and the “Caboodle” will remain in place.
No new converter, yet. I’m planning on a Progressive Dynamics
In that case you will probably only have two DC output wires - black for pos, white for neg. Black would replace the red in your fuse panel, white to white. Be sure to identify your old unit and get the right replacement and confirm wiring from PD or whoever you buy the new unit from.
Thank you.
Awesome. Thank you.
