Press Release THOR unveils hybrid Class A motorhome with 500-mile range
Administrator
Cummins 400 HP
It will be interesting to see how Campgrounds react to this unit. Standard shore power will be charging its battery.
I question the use of hybrid. Maybe I’m overthinking what I read, but it sounds like the ice engine only drives a generator. This generator is not strong enough to directly power the motors, so it’s contributing to battery storage to reduce the rate of draw. Therefore battery alone is 150 miles, while engine and battery are closer to 500.
To drive just on ice is not possible, therefore not like hybrid cars of today.
It's the same way locomotives work, really... diesel generators fueling electric motors.
I think having a huge battery bank and the ability to charge it with solar is awesome. You can park for a week, charge up, and travel with little costs some day.
I think it's 20 years pre-mature, but will be the tech of the future at some point.
Do you think that the ICE will generate enough to run continuously? If so, then I’m all for it.
I know locomotives work that way, but the range limit of 500miles threw my off. If that is the mileage before adding fuel at the pump and going on, that’s amazing.
Judging by the PR, it's not.
150 electric range,
500 total.
so, it can produce another 2x 150, assuming it's likely not drained out before starting up. So, it's clearly underpowered. It can produce about 40% of recharge as it goes.
150 electric range,
500 total.
That’s how I read it too
