I respectfully disagree. Been a Michelin customer for 30+ years. Never a problem. On the motorhome I have always gone with the 7 year rule even though the Michelin’s have always looked great when changed out. Some trucker probably got a lot of mileage out of my old tires.After what I learned I would go Toyo's over Michelin. I lost faith in Michelin. I think Toyo's are a more durable "heavier duty" tire. For those stuck with Michelin for fronts I'd go Toyo's on all others in that scenario.
It's all in the compound!!! This is industry knowledge! I'm not knocking either,as both are great tires. That said,toyos handle uv better, but don't provide the same ride, or traction.I have Toyo’s as well. They seem to be working well. The tire guy that I used told me that Toyo’s hold up better than Michelin’s against UV damage. The tire compound used for Michelin’s is very good for tire wear and performance, but breaks down a little quicker than Toyo’s and other brands.
He said his recommendation would be to change out Michelin’s every 5 years where Toyo’s could last up to 8 yrs.
That’s fine. I really don’t know either way. I’m just referencing what the tire shop owner said. It’s all perspective I guess.I respectfully disagree. Been a Michelin customer for 30+ years. Never a problem. On the motorhome I have always gone with the 7 year rule even though the Michelin’s have always looked great when changed out. Some trucker probably got a lot of mileage out of my old tires.
Curiosity! How do you handle the inside tire wall? You know the pressure side! Also, how do you deal with the tread side? Also the wall you aren't looking at.That’s fine. I really don’t know either way. I’m just referencing what the tire shop owner said. It’s all perspective I guess.
Plus he is in the commercial world as well. In the RV arena we don’t abuse our tires as much, keep them clean, put tire dressing on them, cover them up when sitting for a long time undoubtedly helps the tire.
Good points..Curiosity! How do you handle the inside tire wall? You know the pressure side! Also, how do you deal with the tread side? Also the wall you aren't looking at.
Friction within the tires produce ozone (what causes tire checking).
So how do RV owners really care for their tires??? Best solution is to buy tires that are designed to give what you are looking for!!!
