Toilet issues
jwwradio
Westlake, Louisiana
Sunlite
MJ13
13'
Single Axle
2008 Toyota Tacoma
I have a small Sunlite MJ13 and I am having issues clearing the toilet drain. There is a 90 deg elbow just below the toilet and there has a second elbow that apparently drops into black tank. I try not to use this toilet as we stay usually somewhere with facilities.
I went to WalMart and bought an inexpensive snake. It is too flimsy to make the turns. What other options to clear paper in the piping. I am staying in the camper for work and I have a couple of those little black balloons you put on a water hose and they swell up and build pressure. I am not sure of that is the solution or not.
Any suggestions?
Jeff
Previosly when we've had clogs from too much paper and not enough water, I have found an old fashioned plunger is very effective at moving the blockage along. Have plenty of water in the bowl when you start to "plunge" and generally the pressure from the plunger and water in the bowl will work.
As a preventive...make certain you always have plenty of water in your toilet bowl before you flush, and even then run water for several seconds to keep things from blocking.
I think you've got a 33-gallon black tank on your trailer, so even if you use a full gallon per flush, you've got 30+ flushes before you fill it up.
Lack of water is the probable cause. I find the water pressure to be low when adding water to bowl....
I tried the plunger and some additional water in a bucket but to no avail, get anywhere. I went an bought a water hose and cut off a 3' section and it is catching on something before I can dislodge whatever is blocking. I am by myself on the road working and I know, for a fact, that nothing fell in and that there is no foreign object(s).
I called a local RV repairman and he will come out and look at the problem in the morning. A coworker said his Vent got plugged by a dirt dobber nest and the vapor lock caused his toilet flush problems. Any I have given up and I don't have a ladder with me to look at the vent. Maybe this guy can figure it out.
Jeff W Waldrop
Current location----> South Southwest of Houston
Jeff W Waldrop
You're apparently parked at an extended stay site. You're not leaving the blade valves to your black and grey tanks open are you?
No I keep them closed and when needed I pull the Black tank valve first and when it empties, I pull the grey and pray that it rinses the hose a bit.
That's it, and in the future you need to keep lots of water in the black tank and try to avoid dumping too frequently. Use a TP like they use in public facilities. They use it because it's cheaper you should because it dissolves better. POMS brand which Sam's Clubs carries is a good one. It's however only sold by the case. Any cheap store brand would likely be fine. RV toilet paper is only cheap store brand TP rebranded and repriced.
Any suggestions?
Jeff
The reason my boat's head had a waist paper basket with lid. Carried the habit over to camper life.
We don't use cheap TP. We make sure it's three ply but, when we have to choose a different brand then normal, we test it to make sure it dissolves easy. So long as the package says "septic safe" we have never had a problem. Once we have dumped and rinsed (and the valve closed), we add a couple of gallons or water along with a generous squirt of Dawn. The tank is never allowed to stay dry.
I have taken some irregular items out of toilet pipes. Female related maybe? Some just plain stupid.
