- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Pristine samples! Both are 2-ply.You are testing with proper samples such as soiled test specimens right?
Isn’t camco single ply and charmin 2 ply? (Or more?)
Not sure if you have solved the bidet issue, but here is my input. We recently upgraded to a 2020 Dutch Star 4369. I asked the dealer, TRANSWEST, to look into a bidet toilet for the main bath. They installed a Luxe Bidet Neo 320 (less than $50.00) and it works perfectly (available on Amazon). I’m not sure what the Dometic model # is but I’ve asked them to install one in the mid-coach bath and they did not see it as being a problem.I still want to install a bidet seat in our half bath but can’t find one that would fit the Dometic 8700 series. Interestingly enough, the 8500 series has a bidet seat so I called dometic and asked if the seat was compatible with the 8700 and they said nope. Wouldn’t eliminate the need for toilet paper but would greatly reduce it.
I have not solved it and will definitely look into this. Thanks @El Blondie!Not sure if you have solved the bidet issue, but here is my input. We recently upgraded to a 2020 Dutch Star 4369. I asked the dealer, TRANSWEST, to look into a bidet toilet for the main bath. They installed a Luxe Bidet Neo 320 (less than $50.00) and it works perfectly (available on Amazon). I’m not sure what the Dometic model # is but I’ve asked them to install one in the mid-coach bath and they did not see it as being a problem.
