I have an older 4winds Majestic from 2004. I just found out that the toilet is broken. I noticed a small crack in the (ceramic) bowl, and when I removed the bowl, the underside flange fell off. I think this must have happened when we took her out last time and had to go over 20 miles of unpaved, partially washboard road. Anyway, the toilet is old and I am not upset about this... Now, this toilet (Dometic model 2011 low profile) has been out of production for a while, so I don't think I can find a direct replacement for the bowl (checked with Dometic, no answer yet), and I was wondering if anybody has a suggestion for that. I am not sure if the flange and mounting is different for different toilets, or if there is some sort of standard. I did check out a number of potential replacements on Amazon (to see the customer ratings). Most have a few percent of negative ratings (leaking, foot pedal not working correctly, customer service bad), and similar numbers for good ratings. I'd appreciate if you could drop a few lines if you have replaced a toilet to help me with my decision...
