Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Now for the nitty gritty. with gearing you can do great tasks with a small engine/motor. My ram has 3.72 gears that allow more work to be done than 3.55 gears would allow.
What that means is your transmission would not shift as much if your gearing was different.
Engine size makes the difference on how fast the task can be done. HP is used for this calculation. Torque is the force that overcomes. gearing increases the engine torque the engine produces.
If basically flat land limits what you feel you should be able to do, then the above explains what must be done, Bigger drive train. I am not held back by my drive train, mostly because I have a large enough engine and proper gears in the rear. I will disclose however I travel at 50 to 55 mph. If you make it to California you will find 55 mph max for vehicles towing trailers. Also most interstates have a min speed limit of 45 mph. Let that 45 mph statement be a notice to you that if you travel into the mountains what you are driving may see speeds much slower than that. Another heads up. My 5.7l with 8 speed and 3.72 gears have milage while towing much the same as yours does. However my milage while not towing is between 21 and 16 mpg depending on how I drive. Yes mine is 4x4 as well.
