Towing 2018 Chevrolet Spark
djhenley
Macon Georgia
Tiffin
Open Road
F53
V10
None yet but looking
Anyone have any experience setting up a 2018 Chevrolet Spark for towing, has manual transmission, …thanks
Here is what I googled.
2018 chevrolet spark flat tow
Yes, the 2018 Chevrolet Spark with a manual transmission can be flat towed, also known as dinghy towing
Important Considerations for Flat Towing a 2018 Chevy Spark:
  • Manual Transmission: Flat towing is only possible with a manual transmission 2018 Spark.
  • Battery Disconnection: Chevrolet's instructions for flat towing the 2018 Spark involve disconnecting the negative battery terminal.
  • Neutral Position: The transmission should be in neutral.
  • Accessory (ACC) or OFF Position: Sources indicate conflicting information on the key position. Some suggest the ACC position to avoid steering wheel lock, while others say the OFF position is acceptable if the steering doesn't lock.
  • Supplemental Braking: A supplemental braking system is highly recommended and often required for vehicles towed over a certain weight (e.g., 3,000 lbs.) in many states.
Setting Up for Flat Towing (Manual Transmission):
  1. Position and Secure: Position the Spark for towing and secure it to the tow vehicle.
  2. Parking Brake: Apply the parking brake.
  3. Neutral: Shift the transmission into neutral.
  4. Disconnect Negative Battery Cable: Disconnect the negative battery cable.
  5. Insulate Battery Terminal: Cover the negative battery post with a non-conductive material to prevent contact.
  6. Release Parking Brake: Release the parking brake.
