Travel below 32deg F
rolfesr
I have a 2018 Tiffin Pheaton, an all electric coach. It has a residual fridge with and ice maker and the line to this device runs up the wall behind the fridge.
Does anyone have experience/advice regards driving in freezing temperatures?????
I have turned off the water line to the fridge - for an extra measure of confidence during travel in freezing temperatures. On my newmar there's a petcock valve in the basement where I turn off that line. Should be a similar valve in your coach, just look at the top of the basement near the back of the fridge. I'd still make sure you set your Hydronic heating or furnace to keep the basement zone at a decent temperature. Don't want anything freezing down there. If you don't have one already, get a remote temp monitor system and put a couple in different areas of the basement. I use the ThermoPro system, you can order add on sensors. https://www.amazon.com/dp/B07L82PF1Z/?tag=rvf01-20
