Upgrading my House Batteries
Clodhopper, I replaced my 8 6v batteries last January with three 206 amp hour SOK heated bluetooth batteries. I lowered my battery weight by almost 400#. My magnum 2812 would come on and recharge the batteries every six to seven days when plugged in in the barn. You do need to "close up" your battery bay to keep moisture out.
I'm curious how you sealed up your battery compartment. I swapped out my 8 6V for one 460 ah lithium last week but didn't have anything on hand to seal up the compartment. I had originally thought I'd use foam board insulation board but the walls aren't nice flat panels - there are lots of brackets, bolts, and other protrusions that keeps anything from laying flat against the walls. I'm thinking of using something like a thin rubber membrane. Maybe the membrane you lay down before tiling a shower.
Today was the day to do one last task on my list on my 2017 Newmar Ventana prior to the next trip. I've been wanting to upgrade my 3.4 gpm water pump to a 5.3 gpm pump to see if it can better handle water running in multiple locations such as taking a shower while the washer is running and not impact either. I also wanted to add an accumulator tank as at times the master bathroom faucet will pulsate due to the low demand on the water pump. Having researched accumulator tanks and watched various YouTube videos on it I'm surprised it's not installed standard in all RV's, at least luxury RV's. It seems to handle low pressure demands much better and also extend the life of the water pump.
I changed my REMCO 3.4 gpm aquajet with a REMCO aquajet ARV 5.3 gpm model. Certainly a beefier and slightly larger pump yet remains within the water pump controller power limits and has the same pressure output max so no risk of blowing pipes. As to the accumulator, also went with REMCO's accumulator, looks like a nice quality product. Picked up some fittings and braided water line and off I went.
Spent about 4 hours today removing the wet bay panel and swapping pumps. I guess I see why the accumulator is not standard in all as I really didn't have a good place to mount it. So it's sitting towards the back near the low point drain valve. While the job isn't yet complete, I have about an hour of work, everything is reconnected so at least I could test the pump and it works great. Also something of note is that when you use an accumulator tank the water pump will always continue running about 5-10 seconds after demand for water is off so it recharges the accumulator tank.
While I'm glad the job is done I want to ask the community for a favor. Any time I ever mention doing something that requires taking the wet bay panel off or tell someone it's not hard. Please begin an immediate intervention, or worse, just stop me. I never want to deal with this wet bay panel again and of course all my little mod's to it such as drainmaster automatic gates, SeeLevel, sani-con, dual house filter, etc. Bring me the Advil!!!!
I've been scratching my head over this also.
Punkin,
The left, right, and bottom were pretty easy. 3/4" plywood. The frame rail, I pieced in 2" insulation secured with flexseal spray and flextape for small holes and cracks. Then I cut a piece of plywood for the back wall and secured it to the plywood pn the sides and floor with small pieces of angle iron.
