URPOWER Solar Lights
Staff member
RVF Administrator
I put these lights at the four corners of my coach, I actually removed the forward left one as the slide tipper was triggering it. These motion activated solar powered solar lights are great for security, illumination when you walk in areas so you don't walk into slides, etc. etc. I use the 3M hook tape to attach to the side of the coach, it has not affected the paint as I had to remove the forward left one with no problem. Clean the area thoroughly, use 91% ISO Alcohol for final cleaning and apply - enjoy!
https://www.amazon.com/dp/B012ZPKNFE/?tag=rvf01-20
https://www.amazon.com/dp/B00AQ6IS1G/?tag=rvf01-20
Can you post a picture of the coach with the lights mounted?
TIA
No - it's too cold out. Haha - sure, next time I'm outside I'll get some pics for you.
I would love this if there was a way to manually turn them on/off. I’m not into motion sensor lights at night. They keep me awake because a squirrel ran by the coach
If you can reach it then yes, you could by pressing the on/off switch which you use a paper clip or the included pin thingy.
Is the light bright enough to be bothersome to neighbors at campgrounds?
I also have this question and if not, how can they be modified so that they are
No. If it does they are too close. This is a critical security item to me. We have stuff outside our coaches including expensive bikes.
