Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I put these lights at the four corners of my coach, I actually removed the forward left one as the slide tipper was triggering it. These motion activated solar powered solar lights are great for security, illumination when you walk in areas so you don't walk into slides, etc. etc. I use the 3M hook tape to attach to the side of the coach, it has not affected the paint as I had to remove the forward left one with no problem. Clean the area thoroughly, use 91% ISO Alcohol for final cleaning and apply - enjoy!
https://www.amazon.com/dp/B012ZPKNFE/?tag=rvf01-20
https://www.amazon.com/dp/B00AQ6IS1G/?tag=rvf01-20
