JeffAndPam
- Jun 26, 2023
- Alabama
- Fleetwood
- Flair, 34R
- 34'
Ok, time to post this one here (a continuation of this sub-question here)
So I have this hole in the side of my RV:
I should have placed a ruler by it, but the main hole is about 3 inches high. The hole is indented I'd say a 1/4 in.
For those curious: Basically I was parked VERY close to the roof of our house, this section was behind the rear wheel of the RV. When pulling away from the house, I learned the hard way what "Tail swing" means. Oh, and the patch the roof will be later posted on some other forum.
Some Context on this repair:
I've already got some good tips already. In addition, in my research on patching I came across this video were Evercoat Kitty Hair is used:
That looked somewhat easy. But a bit costly product.
I also found this product: Bondo Hair
I don't see it mentioned much, but this might fit my needs. Especially considering my context.
QUESTION: Does anyone see a downside of using this product for my particular project instead of the resin & cloth approach to fill the hole (then use Body Filler on that)?
OR BETTER YET, given that I don't need it to be structurally sound, is there any reason I can't use just the following:
Bondo Body Filler
for the whole job? That would cut down on cost (I have to buy that anyway) and simplify my fix....and let me got on to the other projects.
- I just want to cover it, doesn't have to be fancy. It's on an 18 year old RV that already has it's flaws. (In fact for spray paint, I'll just find the closet match at the hardware store).
- The hole is about 10 feet off the ground. No one's going to touch it. It doesn't have to be structurally solid.
- I also have other project to get to.
Bondo Body Filler
