Valve stem extender issue on Freightliner/Accuride wheels, again!
My 2023 DS on a FL chassis came without extensions and Newmar said they are not installing them do to safety concerns I know some 23’s had them until the stop was issued.
Interesting… so do you have the integrated TPMS? And can you reach the inner valve?
Good to know. I will be at Gaffney next month. Mine work fine, so I will take them all off and store them before I check in.
Good thought…. But I bet you would need to take the tire off to remove the extensions… no?
These are the aftermarket extensions we used for years prior to going to solid brass valve stems
Thanks Joe. And I used something similar on my old 2007 gasser back in the day, but I am not sure what to use on these aluminum rims…and even less so on how I would install them. I am not really equipped to pull off the outer dually.
Is it ok to reuse valve extenders if they appear and work fine? It's not the cost I'm concerned about but the proper fit, my current setup works well with my flow through sensors fitting and I like to stick with them rather than ending up with ill fitting extenders that can't accommodate my sensors.
Thanks!
Yes internal sensors, require a special tool to remove valve caps and a long, straight inflator
Thanks Stuart. What kind of tool? I have been thinking of developing some type of tool that could be used to attach to the TPMS cap and be able to unscrew it…
Alcoa makes nice grommets for aluminum wheels to stabilize rear inside wheel valve stem https://www.amazon.com/dp/B07ZX9S1C5/?tag=rvf01-20
I don’t know what FL is using now, but for a long time they used Accuride Accu-shield wheels with sort of “D” shaped slots and they use these rubber isolators:
This is what happens to the valve stem extenders when the rubber isolators work loose from their position in the wheel slot:
FD63A779-D7D3-441E-BCC4-FF54B9072334.jpeg67401F04-87C8-4359-8F46-CA780CBE6A79.jpeg7C991A37-49CE-4917-859D-AC512EE381A9.jpeg
The first two pics are a valve stem extender I cleaned up for photos - you can see in the second pic that this stem was very close to failure. I watch them much more closely now.
Thanks Stuart. I need to figure out how to modify that tool to hold the sensors…. But I am thinking it will be tight in there to maneuver…
I’ll keep using the extenders and rubber isolators and I carry a couple spares of each, but as mentioned earlier, I installed the isolators with VHB tape and they haven’t moved since. This is far preferable to dealing with a short valve stem on inner wheel.
I have not tried in my DS, but I could on my Canyon Star. Wasn't very easy, but I was able to do it.
