Rustymayes
RVF VIP
- Sep 11, 2022
- Vacaville, CA
The last few times we had the 4081 DS out I am sure we got adequate heat out of the dashboard heating, as a matter of fact my wife complained that it was too hot. This weekend we took the coach up to Feather Falls Casino and RV resort and drove most of the way in rain and temps in the low 50s. I noticed that with the heat up high I only got barely warm air out of the registers. I checked the engine temp and was surprised to see temps only 115 to 125 degrees F. I would have expected 180 to 200 plus but being new to the DPs I am wondering if this is normal. Then I was wondering if the Oasis heater should be supplying hot water to the dash heat system as it was on. Any insight would be helpful. I am thinking I may have a thermostat issue with only 3600 miles on the coach I would be a bit surprised. While on the subject of possible engine issues I noticed that my Serpentine belt that drives the radiator cooling fan angle drive is squealing. I replaced it with a belt that I bought from a local discout parts house instead of going with Cummins supplied belt. I think the belt was an inch shorter and last weekend after an 80 mile run I noticed that it had shredded one groove off! I put the old belt back on to get home, ran some bar soap on it and the squeak went quite for a few minutes then came back. I plan to replace it with another Alliance OEM belt but wondered if perhaps this is a common issue with the Diesel pushers due to the dirt and grime that coats everything in the ER.
Thanks for the input.
Rusty
Rusty
