View levelers too close to pavement
Notsotalltexan
San Antonio, TX
Tiffin
Allegro RED 340 38LL
Freightliner Custom Chassis
Cummins 340
2021 Jeep Wrangler Unlimited
My brother-in-law bought a 2023 View that has levelers. On their first trip, he drove over a wide speed bump which damaged two levelers and bent the housing. They finally got it back from Camping World where it was repaired. Last week, backing the View out of their sloping driveway, the levelers scraped the pavement.
Has anyone else had this issue and if so, is there a solution involving having someone shorten the levelers and carrying leveling blocks to compensate for the shorter levelers?
Typically, hydraulic leveling cylinders have an array of mounting holes. Is it possible that they could be moved up? Is there room for them to be raised at the frame mounting bolts?
Thank you Randy. I'll run your suggestion by my brother-in-law. He, I fear, is looking into a lift to the frame. He has EQ brand. I told him about HWH but I think he's going the lift route.
My 2025 View 24D has EQ levelers. I have six inches of space between the bottom of the leveler plates and the surface of the pavement. We are getting by with it. I have made contact with concrete forms that mark the end of a parking space., when we back in a space to hang the rear of the RV over grass. I back up slow and stop on contact. I have also made contact with the curb when backing out of our driveway. If I back out so that the left and right rear wheels go over the curb simultaneously, I don't scrape.
My dealer ordered the unit from Winnebago with the levelers. I assume that they were installed correctly.
Is the rear ones being damaged? They may be too far back from the axel. I have Big Foot levelers and they recommend 5’ from axel.
