- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV
I have seen many posts over on iRV2 about wandering tank readings (water, gray and black). Never paid much attention since miner were working. Well now my black tank is wandering all over the place (while empty). I have gone through all the rituals of cleaning and flushing with no change.
I am about to tear things apart to fix the problem. Unfortunately, like so many systems on the New Aire there is no documentation. So it is troubleshooting by braille. So I have some questions.
Are the tank sensors on SilverLeaf coaches the same as those used on coaches without SilverLeaf?
Ben Goodwin posted an excellent video some time ago where he totally disassembled the wet bay on his New Aire to troubleshoot a gray tank tank sensor error. Here is the video.
Ben discovered the gray and black tanks sensors between the two tanks. You can see one sensor here.
The sensor has three wires coming out that make there way to a SilverLeaf interface board on top of the tank. Here is an image.
The three wires from the tank sensor go into the right side of this module (unplugged in this image), while a "telephone cord" cable comes out the left side of the module and makes it's way to the SilverLeaf TM102 module up front. The signal is then put on the SilverLeaf network to be read in various locations in the coach.
Ben found the connector on the "telephone cable" badly corroded and had to replace the module.
You can only get to these components in the NA by totally disassembling the wet bay which I would like to avoid. So are there any similarities between the NA tank sensor system and other Newmar coaches without SilverLeaf?
Any ideas or suggestions would be appreciated.
