Most of that depends on how you drive and care for your vehicle. Get a vehicle suitable for the task and keep the maintenance up, drive sensibly and you should get good service from any of the brands.Wanting to get travel trailer what is most reliable half ton for towing will match trailer to truck
Consensus among most reasonable halfton owners is that you should be able to go up to a ~25 ft travel trailer and still be within the capability of your truck (obviously depending on the specific truck and trailer and how much gear you have).Gary, knowing what I know now, I wouldn't even consider a 1/2 ton for the purpose, unless you're going with a small fold-down or short hardside camper. Getting a 1/2 ton with travel trailer towing in mind is really going to limit you on trailer choices to fit the load capability of the 1/2 ton.
(Sidebar); My definition of a "camper" is a fold down, or hardside of no more than 14 ft. to 16 ft. in length. A "travel trailer" starts at 16 ft. and gets longer and heavier from there. (Although you might be hard pressed to find a 16 or 18 ft. "travel trailer" nowadays.)
My '04 F150, (with factory tow package) has a 7050 GVWR, and it was a bear to find a 5er light enough to stay at least marginally within the weight specs.
Start with a 3/4 ton, and your choices for "living" quarters will vastly improve.
Roger
You don't listen to Tim the tool time Taylor.Consensus among most reasonable halfton owners is that you should be able to go up to a ~25 ft travel trailer and still be within the capability of your truck (obviously depending on the specific truck and trailer and how much gear you have).
