redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Where do you get this water? One would need a lot of it for a wash........ceramic coating will show spots just as bad, if not worse. The key is to wash it while the paint is cool, do it in small sections, and keep it dry asap.
The alternative is to use DI water. I use water that shows < 2 ppm of minerals. This allows me to just wash it and let it air dry.
Once the spots are there, you will need to use a polisher to remove it There is no chemical, no wipe on solution that will remove the spots once they show. It needs to be buffed. When you do the buffing, you are removing a portion of the ceramic. The goal is to remove minimal, and then reapply what you took off.
Its a lot to learn, and only worth it if you truly enjoy doing it.
