Water Pump Issue
Klondike Klyde
Southeast Wisconsin
Entegra
Esteem 29V
32'
Ford E450
V8 7.3L
Ford Fiesta Hatchback
I've got a 25 Entegra Esteem that the water pump doesn't keep running. It'll run for 5-10 seconds, I'll reset it on the tablet or bathroom switch and it'll run again for a short time, sometimes up to 30 seconds and then stop again. I've had in to the dealership a couple of times with no fix. Anyone else have this issue and have a fix?
Did they not try replacing the pump?
The RV is still under warranty and given the problem getting the control pod replaced to fix a furnace, it may take Jayco awhile to approve replacement.
There is a price for peace that seldom includes the corporate world, or waiting for someone else to approve your path.
Waterpumps and inflow strainers are a low cost path to enjoyment 😉.
Having read and re-read your post, I am not sure what you are saying. Are you saying that when you open a faucet, the pump will only run for 10-15 seconds the stop?
Sounds like you have a blockage maybe in your pump screen? The pump works so there has to be a pressure problem. Find the pump, check the filter screen on the intake side. You can remove the intake line and turn on the pump as see if it runs. You will not run it ling enough to do any damage to the pump. Really seems like a pressure problem.
