I have a 2019 Jayco 321. I'm new to RVing so I have a lot to learn. I bought the 5th wheel a few months ago and was wanting to live in it full time.
The weather finally was warm enough to put water in the water tank. I hooked everything up put the valves in dry camping and the pump will not prime. I took
off the suction line , no water. I blew through the suction hose and I can hear bubbling. I set the valves to siphon and put a little water to try and prim the pump
and no luck. Now I don't know what to do next. It almost seems like there is a valve I'm missing. The pump is pressuring air so i do not think its the pump.
Any suggestions would be helpful.
Thank you,
Thank you,
