Rich-MLsRV
- Oct 1, 2020
- Colorado
- Ventana
- Freightliner
- 2020 Jeep Cherokee
Light on panel turns off.When you say "turns off" the light on the panel goes out? Or the pump cycles, off and then on? You might need new pump, but it depends on which of those questions is the correct answer. Additionally, it might be a loose wire or connection, so some tracing of the wiring might be in order.
Where is the water pump controller located. I looked in the water bay but could not find.I think the water pump controller is the cheap and easy first step but agree, it may be a bad pump. I recommend the REMCO AES which is what I use. @MapNerd just installed one, I think the ARV version.
Follow the wires coming off the pump, the black/negative goes to the water pump controller. It's typically behind the left side of the wet bay board.Where is the water pump controller located. I looked in the water bay but could not find.
