Water pump upgrade
No one can tell you that with any certainty. Do you know what your lines are rated for? Mine are 60.
What you may find helps is to add a second pump. 45psi isn’t bad if it’s consistent. My issue was trying to keep shower pressure up while the other sinks were in use.
I added a second pump and now I have great flow all the time. I also have an inline surge tank, set to 50psi.
