turbopilot
RVF Expert
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV, 7.2 kW Propower Generator
A provocative title for a provocative subject. Nothing gets the Airstream Forums more excited than another thread about Weight Distribution systems and Sway Control. Year after year we see these megathreads like the latest one, Swaying to the (music?). These threads always invite a variety of informed and not so informed opinion. Everyone has a favorite solution that they think will work but what drives all the opinions and controversy is that nothing scares a trailer owner more than a potential catastrophic trailer sway event.
What is seldom discussed is the idea that you can design a trailer that will be susceptible to sway and does not require special equipment to avoid a catastrophic sway event. That day may have arrived. We will soon find out.
A few weeks ago I was invited to take a LightShip AE.1 Cosmos on a combination four hour drive and overnight camping trip. I used my own 2023 F-150 PowerBoost pickup and NO WEIGHT DISTRIBUTION device. I “pulled” that LightShip through all highway conditions: windy mountain roads, stop and go city traffic and interstate highways. At all times I had a stiff cross wind out of the West primarily driving North and South along the front range of Colorado. The LightShip was absolutely stable behind the PowerBoost, without any WDH.
Here is a short time lapse video documenting part of my first "tow" of the LightShip AE.1 Cosmos.
My adventure started out with some worry. All of my trailer towing experience has been with my F-150 PowerBoost, my 25’ highly modified 7,300 lb Globetrotter and initially a Blue Ox “bar” WDH then followed by a B&W Continuum WDH. I have never experienced even a hint of trailer sway with either WDH. But those WDH’s are a PITA and heavy. When I pulled into the LightShip production facility to hook up the brand new LightShip production prototype I realized neither LightShip or I had a WDH. The LightShip weight is 1,000 lbs more that my Globetrotter. But they are about the same length. We considered how to do a test drive without a WDH but the LightShip folks said to give it a try without a WDH. The purpose of my trip was to test the LightShip, so off I went without a WDH.
Is it possible the LightShip does not need a WDH? I don’t think LightShip is comfortable making that claim but I experienced enough testing of the LightShip to suspect that such a device may not be necessary with this unique new “trailer”. It is easy to understand as you tease apart all the factors that contribute to trailer sway. It all boils down to three design elements associated with the LightShip that may make a WDH unnecessary. Those elements are:
Let’s tease out each of those attributes then analyze why they all contribute to a very stable trailer.
Very Low Center of Gravity - The LightShip has a very low center of gravity. In addition to the water, gray and black tanks hanging from the frame of the LightShip, there is also a 77 kWh LFP battery, electric motor, gear box and inverter ( weighing around 1,500 lbs) buried in the the frame. The LightShip HVAC system is not on the roof like a typical RV, it is located on tongue of the LightShip. So at least 300 lbs of equipment that typically rides 10’ to 11’ off the highway now rides low on the hitch just above the frame. This configuration has a significant impact on lowering the LightShip vertical center of gravity to a point very low just above the axles. The net impact of this is significantly lowering center of gravity that creates an inherent resistance to a rolling moment that is so important in a catastrophic sway event.
Very Low Aerodynamic Profile - The LightShip is configured to operate in two modes: camping mode and drive mode. The LightShip is designed as a “canopy and tub”. The canopy raises from the drive mode to the camping mode with four electric operated jack screws. In the camping mode the LightShip is 10’ 1” tall. In the drive mode the LightShip is 6’ 11” tall. The LightShip is 8’ 5” wide. The result of the drive mode conversion from an aerodynamic standpoint is that a flat plate equivalent to a 3’ 2” by 8’ 5’” (27 square feet) is not being dragged against the air in motion. Imagine the energy saved by not pushing air against a 27 sq ft flat plate. But there is more aerodynamic improvement as the entire LightShip in the drive mode is aerodynamically refined. There is no obstructions on the roof and the belly is flat with the axles recessed into the chassis not in the slip stream. One more very important aerodynamic trick. The most turbulent area to airflow (ie drag) is found in the area between the tow vehicle rear and the front of the trailer. LightShip reduced drag significantly by designing a stream lined AeroHub that reduces drag while providing a home for the HVAC system.
All of these aerodynamic improvements come into play with for sway control. The flat plate area along the sides of the trailer is significantly reduced. Compare this to a tall slab sided trailer and consider an incipient sway event. As a slab sided trailer begins to sway it presents one side to a high pressure push of air in the slip stream but at the same time it presents the opposite side of the slab trailer to a big low pressure area created by a lift effect. Think of a high slab sided trailer as an aircraft wing flying a 90 degrees to the surface into the wind. When the trailer begins to sway in one direction air pressure builds on one side of the trailer and rapidly declines on the opposite side of the trailer. All this results in the typical whip back to the opposite direction always overshooting a neutral position. This aerodynamic whipping is what ultimately leads to a catastrophic sway event. With the surface area is significantly reduced combined with aerodynamically rounded edges, the Lightship presents a much smaller surface area to the prevailing wind, potentially significantly reducing this lift induced oscillation.
Self Propelled with Kinetic Regenerative Braking - The most significant deterrence to the onset of a sway event is driver initiated trailer braking (trailer only, not tow vehicle). It is common knowledge that nothing aborts an incipient sway event like applying trailer brakes only when sway is detected together with acceleration of the tow vehicle, if conditions allow. The absolutely worst thing you can do is apply tow vehicle brakes at the beginning of a sway event. Tow vehicle braking as sway starts will increase the oscillation of an incipient sway event.
Self propelled trailers using electric motors also incorporate a kinetic regeneration braking mode. When a self powered trailer like the LightShip senses the tow vehicle slowing down the force sensing hitch will automatically switch the electric motor to a generator. In generator mode the electric motor will start charging the battery but more importantly for sway control the electric motor will exert a braking effect for only the trailer, not the tow vehicle. This is exactly the reaction you get by aborting an incipient sway event by manually activating the trailer friction brakes alone.
Here is an example about how kinetic regenerative braking can abort an incipient sway event. Imagine you have just topped a hill with a trailer in tow on an interstate highway. You have a stiff crosswind and about the same time a large semi truck over takes you in the left lane while passing under an overpass. The hill is steep so you initiate tow vehicle braking just as the semi passes you going under the overpass that was partially blocking the wind. All at once the trailer is buffeted by a strong cross wind and a reverse cross wind induced by the semi truck. Your instinct is to apply more tow vehicle braking as the a sway event begins. That is a bad decision. See this video.
Here is a video I borrowed from YouTube then slowed it down with annotations of the various activities leading up to a catastrophic sway event.
Now replay this event with a low profile aerodynamic trailer with dynamic automatic regenerative braking. As the tow vehicle and LightShip enter the same scenario described above there are two big differences. Very reduced aerodynamic surfaces to the prevailing wind but just as important as soon as the LightShip tops that hill it will sense automatically that it should convert to kinetic regenerative braking. That means the LightShip will be initiating trailer braking way before the sway event would have initiated in the scenario described above. In essence the LightShip has a very effective automatic anti sway system that just happens as part of the energy conservation system associated with an EV.
In my four hours “towing” the LightShip with my F-150 the trailer was absolutely stable. The current LightShip firmware will currently support trailer braking using either the electric friction brakes or kinetic regenerative braking. LightShip is targeting to develop a blended braking mode where both regenerative and friction braking can be used at the same time. Right now as soon as the tow vehicle brakes are applied the 12 volt trailer brakes will engage while simultaneously disengaging kinetic regenerative braking. I suspect the automatic onset of kinetic regenerative braking going down hill is the most important consideration to abort an incipient sway event.
So what does this all mean? My initial driving experience with the LightShip suggests to me that it is very possible the LightShip does not need a supplemental sway control device. But what about weight distribution?
This is where it gets interesting. The LightShip has a tongue weight of 820 lbs. The LightShip GVWR is 8,300 lbs. That means the LightShip in tow places just 10% of the trailer GVWR on the hitch of the tow vehicle. Even with my “heavy” F-150 Platinum PowerBoost the addition 820 lbs on the hitch does not exceed the GVWR of 7,350 lbs for two people towing the LightShip. But what about returning the front axle load restoration to the Ford recommended 50% if you don’t have a WDH? Remember the goal of the LightShip TrekDrive self propelled motor is to place virtually no load on the ball by using computer control via the hitch mounted force sensors.
Ford says that you should use a WDH with a hitch weight above 500 lbs and/or a trailer that weighs 5,000 lbs GVWR. On the other hand, I can load up the bed of my F-150 with cargo to the GVWR without a trailer and Ford does not require me to somehow restore weight to the front axle to achieve the FALR recommendation. So the truck has obviously been tested to operate properly with less weight on the front axles up to GVWR, not towing a trailer.
So the suggestion to use a WDH for a light tongue weight LightShip is an open question in my mind, if the trailer is self powered. Obviously a powered trailer is a new type of vehicle. It was just invented. So there is no chance for any SAE guidelines concerning tongue weight and WDH to be developed without a test vehicle.
Based on my first experience I think the advent of aerodynamic, powered trailers will require rewriting the “rules of the road” for safe operation for this new category of RV. It is possible the new guidelines for self propelled trailers will not require weight distribution and sway control.
There is only one other self propelled trailer coming to the market, the Pebble Flow. There are some important differences between the two. The Pebble Flow has no road mode, thus it presents a significantly increased flat plate surface area to the prevailing wind and has a higher center of gravity. It is likely the Pebble Flow will need some kind of augmented device for sway control. But the arguments in favor of specific WDH should be the same.
- Very low center of gravity
- Very low aerodynamic profile
- Self propelled with kinetic regenerative braking
