What does inline fuse from positive battery post look?
Pat O'Sullivan
I posted a question a few days ago about reversing battery terminals which caused all power to MH chassis components to not work at all. I did get some feedback. I'm looking for anyone out there who has the same make/model I have to see if they might know what the inline fuse looks like and where it might be located. I've searched high and low and there has yet to be any info or videos on this exact make and model which relates to lack of current to the main fuse box from positive battery. I'm hoping to fix this without towing it to my closest Ford dealership.
So, here we are again! Seeing the problem is not resolved. First to remember is all the components between all vehicles have the same function. Yes different parts and numbers, but they do the same things.
That said, take the time to follow and read the following thread. You should be able to locate your fuse and have more of a path while troubleshooting your problem.
Thanks for the link, Kevin. I read through it quickly but will read through again to see if what was discussed and discovered will help me figure out what the fuseable links look like and where to find them. All my wires are encased in ribbed plastic proctective sleeves. I'm going to open them up and see if there are hidden fuses between the battery, solenoid and other components.
A fusible link is a spliced in piece of wire, and would normally be in that conduit.
OK. I was thinking it was quite visible and an obvious device attached to the cable. I have another RV Mechanic coming on Thursday but in ther mean time I'll open up the protective sleeves and look for a spice. Thanks again Kevin.
Kevin, good news. I was able to get the old MH started and all components are working perfwctly. The problem was not reversing battery terminals at all. Had I connected them correctly in the first place the MH still would not have started because (this is embarrasing) when I put the batteries back into the MH and reconnected the battery cables, I connected the red cable from the starter to the negative post of my house batteries. Despite 1 RV mechanic and 2 regular mechanics (and a neighbour) no one saw this incorrectly attached wire. I used a little critical thinking a logic to realized that a red cable should be attached to a positive to get power so when I attached the starter wire to the chassis battery I got the proper connections and the MH sdtarted and all lights worked. No blown fuses. I really appreciate your advice as it made me think just a little harder on why nothing worked.
