turbopilot
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV, 7.2 kW Propower Generator
For an complete technical analysis of this trip see this page.
For an HTML version of the content below see this page.
What we learned towing a LightShip 3,719 miles
One truck, one trailer, eight driving days, Arizona to Wisconsin and back. Every second of it recorded. Here is what worked, what it cost, and what we still can't tell you.
The setup: a Ford F-150 PowerBoost hybrid towing a LightShip AE.1, 15,320 lb combined on a certified scale. The two were connected by a charging cable so the truck could refill the trailer's battery from its engine while driving. Nothing was staged — real trip, real destination, real July heat, normal highway speeds. The difference is that the truck was wired to a data logger recording 42 measurements every two seconds, plus a separate GPS logging position once a second. About 1.3 million readings.
Three questions, answered with numbers instead of brochure claims.
1. Yes, the truck can charge the trailer while driving
This works, and it works consistently. The truck's onboard generator sent 5.8 kilowatts into the trailer's battery whenever it was running — day one, day eight, mountains, plains, 60°F and 100°F. The rate never sagged. Single most reliable finding of the trip.
Cost is about three-quarters of a gallon of gas per hour of charging. We measured that two completely different ways — once by comparing a matched round trip in June, and again by statistically separating the charging load out of 18,500 highway measurements from this trip. The two methods share no assumptions and landed within a few percent of each other. That is about as good as field measurement gets.
What one gallon of gas buys you, in trailer power:
| 7.7 kWh | Delivered into the trailer (~7.1 kWh actually stored, after normal charging losses) |
| ~23 hrs | Of refrigerator, at its continuous draw |
| ~5 hrs | Of air conditioning on a hot night — up to about 17 hours in cool weather or at altitude |
| ~$0.48 | Per kilowatt-hour stored, at $3.50 a gallon. Rises and falls directly with pump price. |
Put another way: five hours of driving with the charger on puts roughly a third of the trailer's battery back, and costs about three and a half gallons. Filling the pack from empty would take about fourteen hours of driving and ten and a half gallons.
What it does to fuel economy: towing without charging, the rig returned 15.3 mpg. That figure is unusually trustworthy — we got it twice, on two different days, over 1,080 miles, in weather 15°F apart, and the two results differed by one percent. Turn the charger on and hold it on, and you should expect about 13 mpg at highway speed. Across the whole trip, charging accounted for 3.8% of all the fuel burned — under ten gallons out of 259 — because the charger wasn't running most of the time.
2. The honest catch: hot afternoons
Here is the finding a brochure would leave out. The charging rate never dropped. The amount of time it was willing to run collapsed as the day got hot.
One day in Nebraska gave us this cleanly, because we drove three segments in a row as the afternoon heated up:
| Outside air | Share of driving time actually charging |
| 90°F | 66% |
| 93°F | 43% |
| 97°F | 10% |
Same day, same rig, three consecutive segments. Output rate held steady at 5.8–6.1 kW throughout.
The charging equipment runs a few degrees above outside air temperature and shuts itself down in the low 100s. On a 97°F afternoon it sits right at that line, so it charges in short bursts and spends most of the time cooling off. We also saw it stay off for 30 to 45 minutes after a shutdown, well after everything had cooled — a built-in waiting period rather than a temperature problem.
Plan around it. The system delivers its full 5.8 kW whenever it runs, but on a hot afternoon it runs roughly a tenth of the time. If you are counting on driving power to top up the battery, do it in the morning. Arriving at camp with a full battery matters more than it sounds, because an occupied trailer overnight in summer draws one to two kilowatt-hours an hour just for air conditioning.
A small cost worth knowing about. Leaving the charging system switched on but not actually charging draws about a kilowatt anyway — it just sits there warm, delivering nothing. Over the trip that came to 16 hours and just over two gallons of gas. One early day accounted for more than half of it. By the last leg we were switching it off between charging windows and the waste nearly vanished. It's free to fix; you just have to know to do it.
3. The trailer's motor helping push: a more complicated answer
The trailer has a motor in its own axle. Switch it on and it takes over some of the work of moving itself, and the truck's fuel consumption drops immediately and obviously.
We ran a careful test outside Denver: the same 35-mile loop twice, back to back, once with the trailer motor off and once with it on. Same road, same traffic, elevation within two feet at the end.
The raw fuel rate fell 47%. That number is real, but it is not the honest one — the two systems can't run at the same time, so switching the trailer motor on also switches the charger off, and part of that 47% is simply the charger no longer running. Separating the two effects, the trailer motor's actual contribution is a 27.8% reduction, distance for distance. Still a substantial number, and still the largest single efficiency lever in the system.
The catch. The trailer spent more battery than the truck's charger could put back — by a wide margin, under every reasonable way of valuing the energy. Used as a fuel-saving device on a trip with no plug at the other end, it loses. Used on a trip where you plug in overnight, the arithmetic flips and it wins, because the energy it spends is cheap grid power rather than gasoline run through a generator.
So the fair statement is: the trailer motor is a range-and-comfort feature for people who plug in, not a fuel-economy feature for people who don't.
4. The surprise: heat is a mountain problem, not a desert problem
We expected the hard thermal miles to be the 100°F plains east of Denver. They weren't. The hottest the engine ever ran was on a long climb at 8,000 feet, on a day that was 79°F outside.
Sorting nearly 20,000 highway measurements by altitude, engine load, and outside temperature makes the pattern unmistakable:
| What changes | Effect on engine coolant temperature |
| Climb 1,000 feet | +1.2 °F |
| Work the engine 10% harder | +1.9 °F |
| Outside air 10 °F warmer | no measurable effect |
Thin air is the reason. At altitude there is less air to carry heat away and less air to cool the turbochargers, and both problems arrive exactly when you're asking the engine to work hardest. The engine peaked at 241°F, about 24°F above the point where its thermostat is already wide open and the cooling system has nothing left in reserve. It spent about ten hours of the trip above that point, though only 16 minutes above 230°F and a matter of seconds at the peak — brief excursions on grades, not a sustained condition.
Why this matters. The automated assist system we're proposing was originally designed to trigger on hot weather. This trip says that's the wrong signal — it would have missed the worst thermal event of the entire trip, and two of the three episodes where the engine was actively dumping extra fuel to protect itself. It needs to trigger on the climb instead. That is a design change we would not have found without driving it.
What we still can't tell you
Two things we set out to measure and didn't get, stated plainly because a summary that only reports successes isn't worth much.
- How much of the fuel goes to wind resistance. Splitting the rig's road drag into the part caused by pushing air and the part caused by tires and weight requires deliberately driving at 50, 55, 60, 65 and 70 mph and comparing. We used cruise control the whole trip, which meant 92% of the data sits in a single narrow speed band — not enough spread to separate the two effects, no matter how much data you collect. It's scheduled early on the next trip rather than left to chance.
- Exactly what the trailer's motor draws. The truck's data logger can see everything happening in the truck and nothing happening in the trailer. So when we say the trailer motor spends more energy than the charger returns, the direction of that conclusion is solid but the exact size rests on the trailer's published specification rather than on our own measurement. Reading the trailer's battery directly is the first item on the next trip's list.
The short version
- [MEASURED] Charging the trailer while driving works reliably, at 5.8 kW, for about three-quarters of a gallon an hour — roughly 7.7 kWh into the trailer per gallon of gas.
- [MEASURED] Towing economy is 15.3 mpg without charging and about 13 mpg with it running continuously.
- [MEASURED] On hot afternoons the charger runs only about a tenth of the time. Charge in the morning.
- [MEASURED] The trailer's motor cuts fuel use by about 28% while it runs, but spends battery faster than the truck refills it. It pays off if you plug in at night, not if you don't.
- [MEASURED] Engine heat is driven by altitude and load, not by the weather. This changed a design decision.
- [OPEN] Aerodynamic drag and the trailer's own power draw remain unmeasured, and are the first two items on the next trip.
How to read the labels: MEASURED means we recorded it on the road and can show the data. ESTIMATED means it comes from a calculation with stated assumptions. OPEN means we tried and could not get it, and we say so rather than filling the gap with a guess.
Ford F-150 PowerBoost hybrid towing a LightShip AE.1, 15,320 lb combined on a certified scale. 3,719 miles, 258.59 gallons, 71.8 hours, July 11–24 2026. Route: Prescott AZ → Salida CO → Broomfield CO → Oshkosh WI → Grand Island NE → Moab UT → Prescott AZ. Instrumentation: OBDLink MX+ (42 channels at 2 s) plus TrackLogger Pro (1 Hz GPS). Happy to get into method in the thread if anyone wants the details.
