Wheel Liners?
DMan1717
After 2 tire blow outs and the damage to the undercarriage, does anyone or place sell wheel tire liners for a Forest River Cedar Creek? A liner would help prevent the damage that occurs when the tire blows and tire pieces tear apart the undercarriage. And, YES we are replacing all the tire "bombs" with Goodyear tires. As soon as we get our RV repaired.
I had a blowout on class A diesel that destroyed two storage/utility bays and went looking for the same thing. Unfortunately I couldn't find anything purpose built. Wound up buying the largest heavy duty trucker mud flap made from tire rubber I could find, and repair shop is trimming them to size and installing them in the wheel wells when repairs are completed in about two more weeks. I was fortunate to have little exterior damage to deal with, just a new fender flare and paint to match.
Thank you for that info. I'll look into that.
A few weeks ago you gave me the best info on wheel lines, RV-De-Fender. NOW do you know who in Florida might sell and INSTALL them?
I’m not sure of your mechanical abilities, but it would require the removal of the wheel/hub assembly and the break bad backing plate. Most any trailer repair shop should be able to do it.
I took accurate measurements of the inside of the wheel wells including the bend radius, took them to Tractor Supply and choose the closest match to alum. trailer fenders. With wheels off the fenders were installed and screwed to solid structure. This was cheaper than anything else I could find. Did this before the good Goodyears came out, so the trailer fenders were tested more than once--no damage.
