We burn that hot spot up literally in 3hrs true story! Need better solution!But the simplest response to your question is "does your phone work as you drive down the road?" If the answer to that is "yes" then your phone as a hotspot will also work as you drive as will pretty much all the dedicated hotspots offered by the cellular providers. Yes, there is a lot more sophisticated equipment available, but the bottom line is that cellular service works fine as you travel and can provide very acceptable internet service as you drive. Sure, there will be occasional locations where you lose signal but those shouldn't be frequent, at least not with the 3 major carriers.
I have no idea what you mean by this. We run our hotspots 24/7 without problem. If you used all your data, that's a different story and it isn't the fault of the hotspot.We burn that hot spot up literally in 3hrs true story! Need better solution!
Yah @docj He meant burns through his data.I
