NWIP
- Nov 4, 2019
- No Where In Particular
- Dutch Star 4369
- 43’ 9”
- Spartan K2
- Cummins ISL9
- 2023 GMC Sierra
- Yes
I had the door seal on our 4369 go bad and wanted to replace. Called Newmar and they sent the door seal however it was incorrect. I tried finding online and several glass and bath businesses around to no avail. Called Newmar parts back and after several more back and forths about what I was looking for they sent a picture of the seal, which I confirmed looked correct, see attached. Cost was about $3 less than part they first sent and they refunded the difference. Seal is one piece 7’ in length.
Seal slides into channel on the vertical opening. I will say that installation of this seal requires some disassembly of shower frame. I remove the piece the seal slides into which also holds the magnets but upon removing screws I realized this was maybe not the right approach as nut plates fell to the bottom behind the piece. I was successful with a lot of measurements, some small strips of double side tape to get them in the right place for reassembly. All worked out but might of been better to remove top frame which I was reluctant, see 2nd picture.
Hope this helps, our seal was 4 years old and we fulltime.
