How do you organize and secure your cabinet contents? Post pictures and show us!
Yorick1973
Idaho
Grand Design
Solitude 378MBS
42'
Hi Everyone. Lord willing, we start our full-timing in a couple months. I'd love to see how you experienced RVers organize and secure your cabinet contents. Share pictures if you can.
In particular. what have you done to hold things down and minimize breakage/damage?
Thanks for the question! I definitely understand the challenge of keeping cabinets and their contents organized and secure while on the road. Here are a few tips on how I've set up my RV:
  • Use shelf liners or non-slip mats - These help keep items from sliding around on cabinets and drawers. I line all my shelves and drawers with a soft rubber liner.
  • Use containers/bins for loose items - Any small items like spices, snacks, toiletries, etc. I keep in plastic bins or containers with lids. This corrals all the little things in one place.
  • Use heavy duty Velcro - For lightweight items I can't put in a container, I use heavy duty Velcro strips. These hold everything securely in place but are still removable.
  • Use latches on cabinet doors - Installing simple latches helps keep cabinet doors closed tight so their contents don't rattle around.
  • Pack strategically - I put heavier items on lower shelves and lighter items up high. This helps minimize shifting when driving.
  • Wrap or secure glass/fragile items - I wrap dishes and cups with towels or packing paper to cushion them. You can also use non-skid drawer liner inside cabinets to keep glassware and plates in place.
Let me know if you have any other questions! I'm happy to share more tips on keeping an RV organized on the go.
My cabinet above the windshield - I re-used misc plastic bins from various projects. Keeps a lot of small stuff organized and in one place. I also added the wood strip on the bottom shelf to keep stuff from falling out. Top shelf already had one.
That is very well organized!
Some people use museum putty to keep things in place on counters. It works well and doesn’t leave any marks. I was keeping a house plant and coffee maker in place with it for a while.
Above posts are great ideas, we use most of them.
We have a motorhome, so as we drive we can hear things rattle or move. This has done 2 things:
1) we learned how to store specific items that tend to rattle or move
2) I learned how to better drive to avoid things moving
We put dish towels and hot pads between the pots and lids in the drawers under the stove and paper plates between the real ones in the cabinets. Also use cardboard separators between glasses. We like real cookware and tableware when traveling so we are always finding ways to elimate rattles and avoid breakage.
And here’s a valuable tip: don’t store heavier stuff in high cabinets inside, such as above the sofa. Any swaying while crossing uneven ground, even at very low speeds, is exagerated higher up, so things can be ejected (like an expensive camera and lens) even if the cabinet door seems secure. I got lucky and my camera and lens bounced off the sofa and landed on a dog bed instead of the tile floor, but it could disastrous.
This is my outside supplies cabinet, previously useless pegboard. The shelves were just tempory mock-ups but that was three years ago, so I guess they are good enough. The inventory varies depending on trip duration and any pending road-projects. There’s also a 120v outlet here for chargers, etc.
Tool storage - this tool chest is only 12” deep (had to remove the lid) so it fits perfectly. It also resided in my two previous coaches. I toyed with the idea of a taller box but stayed with this one and installed the shelf above which is quite handy. I moved the light to the underside of the shelf and there is a factory 120v outlet above the shelf.
I also boxed in the area around my DEF tank and installed the sewer hose bin on the left and created more storage on the right, and added a light. There was a lot of wasted space here and I like having Stinky out of the wet bay. I’ve since added a 120v outlet in this space too.
The longer you have a rig, the more you’ll figure out about storage and mods that make it all easier and more organized. I still have more plans for this one.
Eek! Sorry that photo is so huge but this Gorilla Grip will be your best friend. Line shelves, separate cookware, glassware, anything that rattles and it helps things stay in place as you’re underway. It’s awesome and I always keep extra rolls bc you never know when you’ll need it!
My wife uses a lot of plastic tubs and on travel days she adds some foam board. Also use reusable zip ties for cabinets.
We use small storage tubs and we have a set of spring loaded bars for securing items in the fridge. We have wide velcro straps the we us to secure the fridge and ddouble doors to the bathroom storage area. These item along with strateigc placeing of items in the cabinet.
Bins, bins, bins. It helps organize. Easy to pull out to reach the items in the back. I have them everywhere - in the fridge, under the bed, bathroom, drawers, medicine cabinets. Someone should probably take my label maker away from me, but I love it so. 😂
Very well organized and can easily find stuff. I like the outside supplies cabinet ideas. they keep everything in one place.
That is so helpful @Rich W. !!! Thank you so much. It already gave me a couple of ideas I want to implement as it is fitting for my setup - that is, the use of shallow shelves. Did you build that yourself?
Thanks @LoweCountryCamping , that is very useful. I'm ordering them asap.
Love these @RV Accessory Pro! I'm taking notes of these asap. I just ordered non-slip shelf liners that are just the right size for my shelves.
I'm going to get some small containers and bins. I'll check the thrift shop first Tuesday then get additional online if needed.
Velcro? Genius! I can already see some application for this. I'll purchase some strips to have on hand ready to use when needed.
Latches - check! My cabinet doors already have them.
My wife and I will be discussing how best to pack our items once we have everything in place.
I'm still thinking through the dishes and glasses. I have not purchased them yet. Considering going with plastic microwavable ones initially.
Wow! Never heard of museum putty until now. Definitely adding that to my list of ready supplies and already know a few places to use it.
